SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
SOURCE: i have a gestetner 1312 copier it says reset pcu
The PCU is the drum unit. It probably has just worked loose. Just unlatch it and shove it back in to make good connection in back.
SOURCE: how to enter the service mode ? of the gestetner
hello, press yellow colour button,107 cancel button
SOURCE: I have copier gestetner 1312, i want to reset it
yes you you have to do memory all cleare-thanks
