Electrical Supplies Logo
SOLLY Posted on Feb 12, 2013
HOW TO INSTALL LIGHT SWITCH FOR TOYOTA CONDOR
1helpful
After having a new clutch fitted in my Toyota Condor the engine management light comes on after driving a short distance. ie the revs are up
Go to any auto parts store (AutoZone, Advance, O'Reilys...) and ask them to "pull the code" for you (with an OBD2 reader), only takes 5 mins. Once you know why the CEL (check engine light) is on, then you can assess whether to fix it yourself or take it to a mechanic.
2answers
What is the firing order of a Toyota Condor 2.4 of 2rz engine?
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, at v, trucks. forklifts, boats, excavators etc
Headlights are not working on my Toyota condor what can be a problem
Wiring , relays , fuses , sockets and switches can corrode or fail . Do you have a voltmeter ?
How to turn off timing light on a toyota condor 5l
Do you mean the timing belt needs replacement warning light?
What do i need to look out for ,as my dashboard light and exterior park lights are not working. My hazards are working though. I have checked the fuses and all seem ok ..
If it is a General Motors car you most have no tail lights either. Your problem may be the dimmer switch on the dash being turned down...but definitely make sure you have tail lights!
2001 Condor. How can I bypass a immobilizer?
What is a Condor? What USA model does it correspond to?
Toyota condor
please tell me how to program my key for toyota condor
1helpful
I have a 1800 toyota condor, does anyone have the wiring diagram
most likely cause is the horn itself ,check for a feed to the horn before you go any further but some vehicles have a permant feed and the earth is the switch contact connection .if two wires then it could be the latter ? you must check it with a multimeter to determine the fault
Top 3d Rose Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
