Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
