But when i push the menu button it comes on,thats the only thing it does. PLEASE HELP.THANK YOU, FROM;"BROKE IN VEGAS"
SOURCE: Why does my lens close automatically after i turn on my Olympus Digital Camera D-500???
Does it beep or do anything other then turn off? what does it do in play mode? Does it have a good memory card in it? hold the memory door down tightly and try it. Akalines on these older smart media card type cameras just dont cut it they need ALOT more power then you think. NiMH rechargables are the only thing i would recomed using anymore. Dont listen to the tv NiMH are what you need. If you notice on the memory door when it open, there is a little plastic tab that stick out. This tab goes into a little slot on the camera, that slot pushes a button that tells the camera when the door is open and closed. These buttons can sometimes cause problems. So make sure the batteries are NiMH and the door is fully closed with some pressure on it. Also see what it does in playback mode. If it stays on fine in playback mode it may have a lens problem. The mechanism for the lens to move in and out could be jammed
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: When I switch on my camera the lens just keeps
The firmware will need to be upgraded. It is a fault with all digital cameras these days. Company will repair it for $50
SOURCE: OLympus FE-280
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online ++++Thanks for using FIXYA
