Vacuums Logo
A
Anonymous Posted on Feb 12, 2013
Need to change the light bulb on riccar 8850 vacuum
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Jun 03, 2016
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
604383
Points
3345
Remove the bottom plate to be able to pull the light bulb out and replace it.
5 Related Answers
Anonymous
  • 438 Answers
  • Posted on Mar 18, 2010
SOURCE: My Riccar 8850 stopped running.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Testimonial: "Thanks for the information. I pressed the reset button and everything is working fine again."
Anonymous
  • Posted on Mar 19, 2010
SOURCE: My Riccar 8850 belt works but the roller will not spin
I see this same problem posted repeatedly here. The only solutions offered are to "change the belt". When most people state that they've changed the belt and still have the same problem the recommendation is usually "are you sure you changed the belt correctly?".
Bogus. This is a major design issue with the Riccar 8800 series vacuums. It has something to do with the roller and clutch assembly. Either people must replace these every 3-4 months, as they fail at a cost of $50+, or there is another solution and this solution is something other than "change the belt".
Anonymous
  • 438 Answers
  • Posted on Apr 10, 2010
SOURCE: where is the reset button the riccar 8850?
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I think if it just stopped workint all or a sudden, it's prbably the reset switch.
If this was helpful to you, please help other Fixya users find the repair by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Anonymous
  • 1654 Answers
  • Posted on Apr 04, 2011
SOURCE: model 8850 riccar no suction
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
If this is ok, then there probably is still something clogged in the system, Up inside the bottom of the vacuum there is a hole where the dirt goes in to get to the bag. That's where the clog probably is. Also if If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage. Last but not least, the base plate on a vacuum must fit tightly against the bottom of the vacuum for it to get good suction. this is a culprit on a lot of repairs so make sure the bottom of the vacuum is put togethere correctly and tightly.
Anonymous
  • 2047 Answers
  • Posted on Sep 08, 2011
SOURCE: Problem with Riccar 8850 Vacuum There
Hello there, when sparks come flying out of your vacuum cleaner it usually is as a result of messed up connections and power fluctuations.The probability of the motor needing replacement is very high as unless i examine it i cannot say for certain but one thing i can say for certain is that the entire wiring of the unit has to be inspected thoroughly because this is where the main problem would have emanated from. The unit would definitely need other components other than the motor changed this is because if the other components which have been affected dont get replaced then even a new motor will face the same problem after a relatively short period. best refer the unit to an expert to determine the extent to which the other components are affected and what other parts are damaged. Also to determine if the entire motor needs replacement or some part of the motor can still be salvaged.
Hope this support has been helpful?
Thank you for visiting FixYa.
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo.
There is no wiring diagram available
https://www.google.com/search?q=riccar+8850+wiring+diagram
There is a video though
Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual
How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ...
13 pages
How do I change the bulb on my riccar vacuum 8850
Hello, Refer to page 9 of this owners manual. It involves removing a plate on the bottom.
http://media.riccar.com/manuals/8000_Owners_Manual.pdf
2answers
What size belt do I need for this vacuum?
The most durable long lasting belt is available from your Riccar dealer. A Panasonic belt will fit but will need to be replaced more often. All belts should be changed at least once or twice per year.
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
What size vacuum bags does my ricar 8850 take
Riccar style A or B bags will fit. So will Panasonic U, U3 or U6.
Riccar 8850 red light is on and won't go off, I changed the bag but do not know what the light indicates
The light indicates a restriction, a full bag or clog or something restricting the airflow
Riccar 8850 keeps throwing belt
Your vacuum is at least 10 years old. There are some inexpensive parts that can wear or may need adjustment. You have a very durable vacuum that may have many more years of life but Just like a car, needs to be serviced by a trained qualified technician who knows what to look for. It will save you money I the long run.
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
1helpful
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Chris Jones
GoVacuum.com
1helpful
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
