Not sure of your application, but in most cases a three speed motor has two sets of coils (one bigger than the other), and a three speed switch has three leads. Speed 1 uses the small coils, speed 2 uses the large coils and speed 3 uses both. The switch has one input (A) and two outputs (B, C). In the off position, none of the leads are connected together. In speed one, A-B are connected. In speed two, A-C are connected. In speed three, all three A-B-C are connected. With the help of a resistance meter you should be able to identify the switch leads easily. The small motor coil will have a higher resistance than the large motor coil. I hope this helps. Good luck.
