After i open the back by tapping the gaps with a screwdriver and hammer i remove the plastic cap. I find the battery but wont come out easy so it seems that I will remove the metal plate. It has three tiny flat head screws. Do I remove those?
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB
SOURCE: Opening back of watch for battery replacement
Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
SOURCE: my tissot watch st. steel back plate and dial case
All of the press on backs will have some degree of gap (should be able to fit a razor blade in) but .5mm sounds like far too much. Most probably the gasket is out of place or you need a new one. The gaskets in Tissot are notorius for displacing and mishaping upon a battery change. To get these special red Swiss gaskets you will need to go to a jeweler. I would call around to see who has Tissot style gaskets in stock because sending the watch out for repair will cost you at least $50 and this is an unnecessary cost.
SOURCE: size 377 battery wont go in - need to unscew something?
I presume that a 377 battery is the same number as what came out. Sometimes there is a small piece of metal that is a strap that helps hold the batter in. Usually, then there is a very small screw that you have to loosen to remove the plate or just move it a bit to get the battery in. Be sure that the battery is not upside down from the way that the original was placed in. Also when putting in a new battery be sure that you don't use metal tweezers to hold the battery as it will short the battery and discharge it. Use your fingers or plastic tweezers.
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
