On the screen, it said format. So I formatted on my computer, but when I did it erased all my recordings. Tell me what to do
SOURCE: RP5022 digital recorder - file corrupted message
i have a deffical time trying to burn to cd
SOURCE: How do you format a RCA Digital Voice Recorder
It has been some time, but if I remember right.
Insert (up to 256Mb) SD card in slot.
Turn the unit on (Press hold > (PLAY button)
Press Menu button
Use >>| (FastForward button) to select from "INT"ernal memory to "EXT"ernal memory
Press STOP button
A message "WAIT" will be displayed.
If I remember correctly, it will ask to format if it needs to. (Use >>| (FastForward button) or |<< (FastRewind button) to select "YES" or "NO".
You can alternately use a PC to format as FAT (Not FAT32) file system.
As you use the unit, it will create FOLDER1....FOLDER9. In fact it will create each folder, each time you go to view any of the 9 folders that aren't already there. Until all 9 folders are created.
I haven't had to format my 256Mb SD card. I just inserted it, and it was fine. (Even ones I had previously used with other data, the DVR will simply create folders "FOLDER1", etc. if not already there, and use them. )
SOURCE: I have about 10 interviews on my recorder. It
DO NOT format the recorder. That will wipe it clean. The computer does not recognize the device. There must be a piece of software needed to allow the computer to recognize it. If you have an old pc forget it. Dont know about macs.
