SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
SOURCE: Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
SOURCE: Chaning input without remote
Radio Shack vende un adaptador para que conectes el juego por el lado de la antena este aparato entra por el canal 03.
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
