Please attempts to use oil to help gently open the door . Or you can start the machine and attempt to open the door then. Running the machine might free up the lock somehow. Thank you.
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
If your Frigidaire washingmachine
started spinning, but then stopped, verify that the power cord is still
connected to the outlet. See if the outlet blew by plugging in a
different appliance into the outlet. See if you blew a fuse. A blown
fuse usually is either black or has broken wires. Replace the fuse. If
you have a circuit breaker instead of a fuse box, reset the circuit
breaker if it's been tripped. Check the lid switch, which is located
inside the main housing of the washing machine, near the door frame. If
the switch is burned out, order a new part from a Frigidaire parts
dealer.
Pump
The pump's sole responsibility
is to remove water during the spin cycle. If the pump isn't working
properly, see if it's clogged with debris or clothing. Use needle-nose
pliers to remove these items. Check the pump pulley, which is connected
to the pump. This component must move freely for the pump to work. If it
won't turn, purchase a new pump pulley since you can't usually fix this
component.
Lid
Check the door latch assembly if
the door isn't closing correctly. If any of these components are
broken, order a new part from a Frigidaire parts dealer. If you do not,
the washer
won't start spinning since it believes the door isn't closed. Your
Frigidaire washing machine won't start the spin cycle until the lid or
door is closed. Always close the lid, and remove any items preventing
the lid from fully closing. Always close the dispenser drawer.
Additional Concerns
Never over- or under-load your
washing machine. Your Frigidaire washer may not enter the spin cycle if
the load is too large, since this can damage the washing machine. Remove
a few pieces of clothing. If the load is too small, add a few similar
items to the washing machine. Check the internal belt, drive motor and
motor coupling. If any of these components are broken or very worn, they
may not work properly, preventing the washer from entering the spin
cycle. Order replacement parts from a parts dealer. Check the tub and
basket bearings, and get new ones if the current ones have broken
components or are defective.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
