My son has accidentally locked my ipod touch and disabled it. How can I fix it?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
IPod will be disabled when it is locked with passcode and you entered too many times' wrong passcode attempting to unlock it. However, the next times you come across this problem, you should not enter too many times' wrong passcode but use proper tricks to get rid of it.
Both DFU mode and recovery are good choice to fore reset your iPod.
As to recovery mode, perfect tool ReiBoot is recommended here to enter and exit iOS recovery mode. It is totally free, have a try! Tenorshare ReiBoot
SOURCE: How do I Unlock Ipod screen if I forgot the 4 digit password?
There are basically three ways to unlock the Screen Lock on your iPod:
If your iPod is simply frozen, follow my instructions for an iPod Lockup Reset.
Everything on your iPod will be erased.
This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked. Besides, if you don’t unlock your iPod it’s useless right? Learn how to Restore your iPod using the instructions from Apple’s site.
or
I've tried the below method, and my music is still intact]
Step:
1. Plug in ipod.
2. Open “My Computer”
3. Look for the removable device (which is your ipod).
4. Open the folder, search for this hidden file : _locked.
rename or remove(delete) this file.
5. Eject your ipod.
Done.
SOURCE: how do i fix an disabled ipod touch ?
you can reset its password....but you'll lose all your data
here's how...
Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
SOURCE: My son forgot his password for his ipod touch, it
To unlock the iPod, you will need to put the iPod into recovery mode, and then restore the iPod through iTunes.
To do this:
1) Turn the iPod off.
2) Hold down the iPod's Home button and plug the iPod into the computer it was last synced with.
3) Release the Home button when the iTunes image appears on the iPod's screen.
4) Wait for iTunes to recognize that the iPod is in recovery mode, and then follow the onscreen instructions to restore the iPod.
Note: You may lose some of the information stored on the iPod.
If you cannot unlock the iPod after doing this, you will need to call Apple Customer Support.
SOURCE: My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes. Then restore it. Let me know what happened.
SOURCE: ipod touch is locked forgot password cant unlock
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
