I removed harness to wash and have refitted shoulder straps but adjustment strap on Viaggio Primo SIP wont thread through and under buckle . can you advise please
SOURCE: trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
SOURCE: Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
SOURCE: car seat instructions
Here is the link to the online manual for the 2007 Perego Car Seats. give it a few seconds to load. It will be a white page while it loads.
http://www.pegperego.com/pegcatalogue/juvenile/downloads/PrimoViaggioSIP-US_FIUS0603I61.pdf
Follow the remove instructions in reverse. It is difficult to describe, but the pictures are very helpful.
Good Luck! from Moms Just Know
SOURCE: i've removed the maxi cosi cabriofix cover to wash
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
