Dell Inspiron 1545 red processor:Pentium(R) Dual-core CPU T4400 @2.20GHz is error code 2000-0221
This is a bios level error, you should still be able to run the system. this code is something you get when you hit F12 and run the diagnostics? or is this a blue screen error? you are probably going to need to boot to F2 (setup) then hit "Alt e" Alt F then Alt B the system will beep on the alt f but that's ok once this is done hit esc, save changes and reboot and see if you still get the error
SOURCE: How can a know what cpu's my inspiron 1545 supports
Intel Celeron and Core 2 Duo mobile processors
http://www.notebooks.com/2008/12/19/dell-inspiron-1545-coming-soon/
Memory DDR2 PC2-6400 RAM
http://www.crucial.com/store/listparts.aspx?model=Inspiron%201545&pl=Dell&cat=RAM
SOURCE: dell inspiron 1545 problem on installation,problem
1. boot to cd/dvd rom using the dell resource drivers utilities. you need to test the dvd drive if it is working, if yes, we might have 2 problems it might be the dvd installer or the hdd. run a test for the hdd to isolate the issue or you can try to run the installer to a diff computer to test if dvd installer is not faulty.
SOURCE: hello sir plz help i have dell inspiron 1545 with
Hi, I am going to help you with your problem. Follow these instructions 1. Click on the (Start) button on the Taskbar. 2. Point to (All) Programs; in the Start Search window type: Dell. 3. Scroll to find, Dell Application / Driver Installer. 4. The Dell Application and Driver Installer appear! 5. Scroll to find the Bluetooth application. 6. Click on the application to Highlight, to the right, click Install. 7. Follow all the instructions thereafter carefully! I hope this helps out, thanks paul7of9
SOURCE: I want to upgrade my inspiron 1100 processor
To be honest, the Inspiron 1100 is probably not worth the effort and cost to upgrade
The fast is proc is a 2.4 GHz Pentium 4 CPU, max ram 1GB of RAM,
You can find several dell portables below $500
http://www.dell.com/us/en/business/notebooks/vostronb/ct.aspx?refid=vostronb&s=bsd&cs=04
http://www.dell.com/us/en/home/laptops_great_deals/fs.aspx?refid=laptops_great_deals&s=dhs&cs=19
SOURCE: Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
