Canon pixma keeps jamming, Tear down and look inside for small shreds of paper and blow out.
There is infact a very small peice of paper in the printer, they will pickup on the smallest peice. if you have thoroughly checked the rollers in the printer then open all compartments, paper , lid, ink , back. then unplug the printer wait a few minutes plug back in hit power then close all compartments to reset printer
SOURCE: My printer won't print.I have
try to look for the cassette it is located in the lower portion of the printer you can pull it to load paper
SOURCE: Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
SOURCE: I had a paper jam Problem with the PIXMA? iP6009D
there might be some paper stuck in the rollers or which is blocking the sensor hence the msg. just give it a good check
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
