SOURCE: LAN DRIVER FOR 945GZM-S2
here you go.
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2425
SOURCE: driver
Here you go .. have fun
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2603
SOURCE: How can boot from usb drive from ga-945gzm-s2
Hello Amzy, hi! If you are planning to boot from a bootable USB flash drive, at boot-up you press F11, you will go to a boot menu, then select the USB drive. If your question is how to make a bootable USB flash drive, go search Youtube for the instruction on how to make a bootable flash drive.
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
SOURCE: help me find driver for GIGABYTE GA-945GZM-S2
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
