TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
  • 8,617 Answers
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Posted on Feb 09, 2013
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Posted on Jun 28, 2006
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Posted on Jan 17, 2008
Anonymous
SOURCE: picture turns off, but sound stays on, bulb has been replaced recently. Happens 5-10 times a night
did you try the Ballast
Posted on May 01, 2009
circuitworld
Circuit World
  • 335 Answers
SOURCE: Sxrd rear projection standby light blinking 4
check the bulb door and make sure its closed all the way. be sure the bulb is firmly pushed into its socket. if the problem is still there you may need to repair the power supply board.
Posted on Jun 17, 2009
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
I have a 55" Sony Rear Projection TV and when I turn on he TV I hear the voices but it takes the picture about 30 minutes to come on? The bulb was replaced less than years ago
First is the model listed here does not use a bulb, it has 3 picture tubes. What is actual model number as I think wrong one is listed here.
Dec 20, 2012 | Sony KP-51HW40 51" Rear Projection...
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
I have a 2 year old Sony Bravia KDS 50A3000 rear projection TV. We replaced the bulb about 2 months ago and now all of a sudden the bulb will go off and we loose the picture for 35 seconds, nothing happens...
well if you replace the lamp 2 months ago this could be a ballast issue go to your back of the TV and if you ear a weird mechanical noises like a tick,tick when you are down there this is the ballast.
Regards
Dec 16, 2009 | Televison & Video
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
