2006 Toyota Prius Logo
Posted on Feb 05, 2009
2006 Prius rear door panel removal
I need to replace the rear spoiler on my 2006 Prius and can't figure out how to remove the interior panel(s) to get at the spoiler fastners.
STEVE WOODRUFF
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 28, 2009
STEVE WOODRUFF
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
22875
Points
26
The black plastic is removed my prying away from the hatch, start with the most bottom piece.
the instructions in the owners book for changing the lamps shows this as well.
there are many pop style plastic fasteners
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Sep 23, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
26897
Points
67
First off you will need to go to the dealer and buy i think its twelve plastic compression screw the little plastic pieces that slide into the panel and you push through the holes in the frame either use a thin flat head screw driver or sears or most auto part stores will will sell an interior panel removal tool for about five to six bucks use that just start on one side of the panel and slowly work you way around it will just pop right off
5 Related Answers
Anonymous
  • Posted on Mar 04, 2009
SOURCE: To remove the interior door panel of a 1996 Toyota camry so that
My 96 Camry LE has 9 attachments that are visible. Some have plastic caps covering the screws; others do not. There are screws at the door handle, at the forward portion(with covers) when the door is open and the back edge (small covers). As I recall, there are several friction type fasteners around the perimiter of the panel that can be removed by prying carefully away from the metal portion of the door to free up the trim panel. Once these are loose, the trim around the inside door release handle (the one you pull to open the door) can be pryed in a backward motion. Then the entire panel can be removed by pulling upward and backward at the same time (it easier to do this with the window down). Then it is a matter of disconnecting the wires attached to the various controls for the electric windows and door locks to free up the panel itself. There is probably a plastic skin covering the metal portion of the door. Carefully pull that away to expose the inner workings of the door latch mechanisim. The rest of the procedure should become easy to figure out. I have not removed the exterior door handle itself; but it is a simple mechanism as I recall. Best of luck to you.
Timmy P.
Anonymous
  • Posted on Apr 06, 2009
SOURCE: removing door panel in 2000 toyota corolla
remove phillips scew and the door handle. remove padded arm rest on the door by lifting it up, and remove 2 screws. You can use a panel tool to remove the plastic toggle like pins holding the panel border in. Be as gentle as possible they may break due to becoming brittle.
Anonymous
  • 62 Answers
  • Posted on Jul 11, 2009
SOURCE: How do I remove the front interior door panel polo 1400 1999
You'll need a torx bit for the bottom screws. The door handle comes apart (using a screw driver) to expose 2 phillips screws holding the door handle to the door, after you get those out, pop the rest of the push clips out by firmly pulling on the door panel near the bottom, There may also be another screw on the TOP Front (near the mirror) very small phillips. Once you have the door panel loose, lift UP on the door panel to remove. Once you get that panel off, you'll have to remove all the other screws to get the window regulator out (lots of 10mm bolts). Unclip / unconnect the connections etc..
Anonymous
  • 1986 Answers
  • Posted on Sep 14, 2009
SOURCE: i need to remove the rear door interior panel on
on the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.pull back the weather seal and you'll be able to get to the track
vtrktrmn
  • 201 Answers
  • Posted on Sep 18, 2009
SOURCE: How do I remove the passenger side interior rear
There are insert in the door that hold the panel on, you can get a tool to help you remove the panel at your local auto parts store. This will help prevent damage. You also have to remove the armrest and once retainers are loosened at the bottom and armrest is remove slide door panel up. No problem but be careful not to damage panel.
2005 Prius front door handle will not open from inside
The interior door panel needs to be removed to figure out what broke. After the interior door handle is exposed you will be able to quickly identify if the problem is the handle, the cable or the door latch.
How to remove high mount lamp 15 ford edge
Hey Ray I'm looking at a picture of this vehicle but I can't see if the lense has screws in it probably not otherwise you wouldn't be asking anyway I think that you will have to remove the rear door trim panel look for little screw covers and pop those out if none then that panel has clips under it and lightly pry up on them from under the panel to release it and I see that it's in the spoiler so there might be a panel to pop out on that trim panel at the top because that spoiler is not part of the rear door it's a bolt in part attached to it from what I can see in the photos and please go to Tasca parts .Com I just found this body/spoiler for 2015 ford edge there's a diagram of the spoiler with fasteners Tasca is a ford dealer in I think Rhode Island but this diagram should help you good luck stephen
Replace third brake light 2005 Equinox
From the GM 2005 Chevrolet Equinox Service Manual:
Remove Spoiler:
1. Open the liftgate
2. Remove the liftgate upper interior trim panel to expose the center bolt
3. Remove the spoiler to liftgate bolts (3)
4. Disconnect the stop lamp harness
5. Disconnect the rear washer hose
6. Lift the spoiler to disengage the locating retainers and remove the spoiler from the liftgate
Remove the high mounted stop lamp assembly:
1. Remove the spoiler to high mounted stop lamp screws
2. Disconnect the electrical connector
3. Disconnect the washer hose
4. Remove the stop lamp from the spoiler
Install the high mounted stop lamp assembly:
1. Position the stop lamp assembly to the spoiler
2. Connect the washer hose
3. Connect the electrical connector
4. Install the spoiler to high mounted stop lamp screws, tighten to 2 N-m (18 lb in)
Install Spoiler:
1. Position spoiler loosely over the liftgate
2. Connect the rear washer hose
3. Connect the stop lamp harness
4.Push down the spoiler to the liftgate to secure the locking tab retainers
5. Install the spoiler to liftgate bolts; tighten to 2 N-m (18 lb in)
6. Install the liftgate upper interior trim panel
7. Close liftgate
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
How do i remove inside rear door panel on fiesta 2015
Ford Fiesta Plastic Interior Door Panel Removal Guide ...
www.paulstravelpictures.com/Ford-Fiesta-Interior-Door-Panel-Removal-...
Ford Fiesta Interior Door Panel Removal Guide How to take off the plastic interior door panels in a 6th generation 2009-2015 Ford Fiesta to upgrade the ...
Ford Fiesta inner door panel removal (I removed the top one ...
www.fiestafaction.com/.../44959-Ford-Fiesta-inner-door-panel-removal-...
Jan 19, 2015 - 10 posts - ‎3 authors
This is an excerpt from the manual: Remove the rear door window glass. ... Route theinterior door handle cable and door lock actuator electrical connector through the ...Last edited by WildmaninME; 01-19-2015 at 07:41 PM.
Ford - door panel removal - fiesta - YouTube
? 2:19
https://www.youtube.com/watch?v=1URT13Yusjg
Oct 19, 2013 - Uploaded by one2three
this is the removal of a door panel from a ford fiesta 2001. ...Replacing Broken Inside Door Handle on 2007 Ford Fusion - Duration: 5:32. ... Ford Fiesta 1.25 2004 - Cleaning and adjustingrear brake drums - Duration: 8:47.
How To: 2012+ Ford Focus Rear Door panel removal(SE,ST ...
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Prius back door locks
Yes,the lock mechanism has either gone bad and needs replaced or is disconnected from the system.Whether it be accidentally disconnected while repairs being done or wire fell loose,pull the door panel and check it.If connected and has power when checked with a test light,it should work.If has power and no action,replace it.
5helpful
Step by step instructions for rear bumper cover removal on a 2005 Prius, including bolt and plastic rivet locations.
Hi.
Here you go:
1 - Remove one screw at each side's fender:
2 Remove two screws and clips at the back.
3 Pull out the bumper.
4 If needed remove screws holding spoiler support
5 Perform operations in reverse order to reassemble
Serious rear spoiler noise
I all unbolts from the interior of the trunk.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
