I've completed installation of my garage door opener and it works but does not do up all the way and I've adjusted the open function as far as it will go. It's about a foot short of full open. What should I do next?
If the springs were broke, it would not go up that high. It would only go up about a 6 inches and stop or strip out the gears. Either your limits are set too low, which means you would need to go through the programing functions again. It could also be the force setting, which again means you would need to go through the programing functions again. The only other thing that would cause that is that you bought a 7 foot opener for an 8 foot door. Post a photo's and I could help you more.
Check that none of the springs are broken. can you manually push it up the rest of the way?
