Brother CS-6000 Logo
Anonymous Posted on Feb 05, 2009
While sewing the bobbin case moves, wheel locks up, needle locks
Hi i have a brothers sc6000 . I will be sewing and everything will lock up.Seems the bobbin case will not stay in place.Put everything back together and the wheel will be hard to turn to even wind the bobbin thread up to begin sewing. I will put things back together and 3 minutes later same thing happen bobbin case moves and needle bends, locks up ,or breaks. Can you please shine some light my way? Thankyou
  • 2 more comments
  • vaavaavoom Feb 06, 2009
    Have the same problems. How did you solve this?
  • hauntedheart Feb 08, 2009
    I have the same problem. The black bobbin case moves counterclockwise. There is a metal band and a small "nib" in the case that the thread passes through, but the "nib" passes the metal band, and the bobbin case spins, and the machine jams.
  • Anonymous Apr 05, 2009
    My bobbin case slides and it causes my needle to hit it and jam up. My machine also doesn't pick up the bobbin thread when it sews.
  • linzai92 Apr 19, 2009
    i have the same broblem and i figured it out. there is a small metal peice that keeps the bobbin case from spinning. this peice is tiny and easily bent. if it gets bends the bobbin case spins to far and whne the needls goes down it hits the bobbin case, causeing it to bend or break. how ever i do not know what this smal medal peice is called or how to repplace it! any suggestions?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1537
Points
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
My baby lock lock up while sewing the needle want move up and down it is a grace it says error 6 can you help me thank you
Sewing Machine: Needle won't move
A disengaged clutch, broken drive belt or internal drive gear failure can prevent the needle from moving. Engage the hand wheel clutch if you have it disengaged for bobbin winding. If the needle won't move with the clutch engaged, unplug the sewing machine and check the drive belt.
https://www.searspartsdirect.com/diy/symptom/sewing-machine-repair/1234596/needle-won-t-move/smac1011147
How to Fix Brother Sewing Machine Error Code E6 Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
2answers
My pfaff 6122 got knotted in the bobbin and now my needle wont move? HELP the wheel seems locked and when i move it it jumps into place and locks
I'd guess there's still thread in the hook. Try removing bobbin and case and clean area per machine instruction.
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Brother CS6000 computerized machine bobbin case moves and locks up
The Black bobbin case more than likely is not installed correctly.
The machine just won't sew with it rattling about in it's space.
Machines do have levels of quality. Proper maintenance is a must for any busy sewing machine who's owner is expecting a trouble free use.
Cheers,
Embroidery Services
San Diego, CA
3answers
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
1helpful
2answers
I have a Singer XL5000 machine, the normal looking bobbin is not spinning with the shaft and wont wind what have I done wrong?
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
