How to reset memory
Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list.
Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
