You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Have you tried booting up in safe mode to see if it does the same thing?
Also check your keyboard to see if there is some type of key
combination that locks or unlocks the numeric keypad. If so, usually
you will have to hit the FN key or the ALT key or the CTRL key plus some
other key to get it to toggle.
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key (in the top row of the keyboard) to turn number lock on or off. When number lock is on: • Keys change to the numeric or arithmetic designations printed on the right side of the keys in the numeric keypad area. • The Num Lock status indicator is lit. • To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
I'm afraid that is not possible. The only way to overcome this is to get a full size USB keyboard and plug it into the laptop's USB port and type using the full size keyboard.
