"DC to AC" cords are not really a common item. They are called "Inverters". Typical inverters are 12VDC to 120VAC and are found in mobile applications to operate houshold current type (120VAC) devices. Inverters cost many times more than thier "AC to DC" or "AC to AC" sisters.
An "AC to DC" and "AC to AC" cord however, is a very common item. They are usually called simply "AC Adapters" and are sold in many electronics stores (Best Buy, Fry's, etc.) and electronic specialty stores (Radio Shack) and electrnics suppliers (MCM, etc.) Nearly all of them are designed to reduce the voltage in your home (120 VAC volts alternating current) to a different but usually lower voltage that is either AC or DC.
In order to select the proper AC adapter, you need to know:
(1) Input Voltage - this is the outlet voltage - often 120 volts in N. America, (2) Output voltage - this is the voltage the device needs and is often indicated near the jack, The adapted must match this voltage. (3) the device voltage type - this will be either AC or DC. The adapter must match the type as they are NOT interchangeable. (4) the size and type plug on the cord that will allow it to mate properly with the jack. There are many, many types and it should be tested for fit prior to plugging in and must match the device jack (5) the power requirements - this is usually shown as a number in Watts (w) and / or Amps (a). It is very important that the apdapter power rating is equal to or greater than the amount specified by the device. Failure to meet the requirements above can cause failure of the device, adapter or both.
I hope this helps and good luck!
