What is a t305? It must be a device which can type a passcode. A passcode is a number that Bluetooth devices use to confirm that it is safe to connect. If you pair two mobile phones, it asks for a passcode. You enter it in one and then the same in the other.
If the t305 is not a device which can enter a passcode, then you need to refer to its manual to see what to do if the phone asks for a passcode.
Hope this helps; also keep in mind that your
feedback is important and I`ll appreciate your time and consideration if
you leave some testimonial comment about this answer.
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Passcode is usually 0000. I use it whenever I change phones and it always works. Don't know how to change it, nor do I even know why you would want to.
it is a hands free device
