Question about Intel Motherboard
VIA/S3G UniChrome Pro IGP drivers and realtek ac97 driver problem
Hello i m having problems with my sound and graphics.i have need for speed most wanted installed on my windows xp sp2.but it crashes after few minutes.when i had vista it was running fine.somebody told me that this is driver problem. i checked some of my driver files are not digitally signed.i m tired searching for latest drivers.plz help where can i get latest drivers.my system specifications are as follows:
System Information
Time of this report: 10/11/2008, 07:11:46
Machine name: SHERGILL
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-7312
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: AMD Sempron(tm) Processor 3000+, MMX, 3DNow, ~1.6GHz
Memory: 446MB RAM
Page File: 294MB used, 759MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file vtdisp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file viaudios.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: VIA/S3G UniChrome Pro IGP
Manufacturer: VIA/S3 Graphics, Inc.
Chip type: VIA/S3G UniChrome Pro IGP
DAC type: Internal
Device Key: EnumPCIVEN_1106&DEV_3108&SUBSYS_73121462&REV_01
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: vtdisp.dll
Driver Version: 6.14.0010.0180 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/7/2004 11:07:54, 3325184 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: vtmini.sys
Mini VDD Date: 10/7/2004 11:08:02, 174592 bytes
Device Identifier: {D7B71FE6-7248-11CF-6677-1853A0C2CB35}
Vendor ID: 0x1106
Device ID: 0x3108
SubSys ID: 0x73121462
Revision ID: 0x0001
Revision ID: 0x0001
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: VIA AC'97 Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_1106&DEV_3059&SUBSYS_B0131462&REV_60
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: viaudios.sys
Driver Version: 6.14.0001.3870 (English)
WHQL Logo'd: No
Date and Size: 6/16/2003 11:05:40, 369920 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Standard
Cap Flags: 0xF5F
Min/Max Sample Rate: 48000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFF0
DirectMusic
DLS Path: C:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
VIA AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
----------- i don't have a whql logo to use my onboard vga.
  • Anonymous Mar 12, 2014
    Video Card 0: vtdisp.dll VIA/S3G UniChrome Pro IGP Vendor(0x1106) Device(0x3108
    Champion:
  • 203 Answers
6ya staff
SOURCE:
Have compaq cq40-327tu laptop. i need to install windows xp sp2 but i am not able to do this because of sata driver problem. Help me to overcome this issue. Also i need xp drivers for the same.
Hello, if you want to install window xp sp2 on a sata hard drive,then when you install your operating system CD,a section will appear under your screen, where it will ask you if you want to install on a SATA drivers and that you should press F6. What out for this and press F6, and i believe the problem should be solved. Cheers.
Dec 08, 2010 | Computers & Internet
My audio device is not working. so i want to sound driver for it.
You can download all the drivers you need for Lenovo 3000 Y410 Laptop from the below link
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html#audio
Just scroll down the page for Audio drivers for both win XP and Vista,click on the blue version number to download the one you want.
Note : Incase you have win XP,some people has issues installing the xp driver with sp3 installed,the driver seems to work with only sp1 and sp2.So if u have SP3 and unable to install xp driver, do one of the following.
1) Uninstall SP3 and install SP2 and then try installing the driver for XP
2) Download Vista driver and install it with windows compatibility mode set to XP SP2.
Nov 30, 2010 | Lenovo 3000 Y410 Laptop
No graphic after install XP SP2
Have you updated XP to SP3 as recommended? Did you  installed the latest available video driver after after that ?
May 26, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
NFS Most Wanted problem
this usually happens when u have less memory available on your RAM or your Graohics card.
Try upgrading ur GFX card or RAM or Both.
When i faced this peroblem, it helped me tons.
Mar 24, 2009 | EA - Electronic Arts Need for Speed : Most...
Do direct x 10 supports windows xp sp2 ? i'm asking this b'coz i have recently installed it but there is no improvement in games performance or in video >.i have windows xp sp2 installed
Hey,
Dx10 comes with vista, microsoft doesn't give dx10 to xp, xp has dx9.
you can try this alpha, unofficial dx10, not made by microsoft..
http://www.techmixer.com/download-directx-10-for-windows-xp/
it comes with no warranty of actually working, try at your own risk.
Let me know if you need anything else.
Thanks,
Ek
Feb 25, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Sound not come in win xp
1st u say what type of motherboard u use......
open ur xpsp2 then install sound driver
setup ....then cancel then wait ...restart
Jan 20, 2009 | Microsoft Windows Xp Home Edition Sp2...
ATI RADEON x1650 PRO 512 Crash...
Their is a reason that it crashes and it is not because of the game if  it crashes at other times too. Toom much HEAT is usually the problem. Look for slow or stopped fans. Dust on the heatsink.Run the antivirus. After that clean and defrag the hard drive. Let me knw that that did not take care of the problem.
Jan 18, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Intel Motherboard Logo
1,344 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
