HEWLETT-PACKARD CP1025nw Laser Printer Logo
Anonymous Posted on Feb 07, 2013
Unexpected paper size - HEWLETT-PACKARD CP1025nw Laser Printer
1helpful
Unexpected paper size message
go to the printer preference settings and change the paper size to A4 if you are using A4 and paper type to plain paper. and do the same on the printers settings menu.
HP 2840 unexpexted paper size
You must properly configure your paper size from the menu.
If you can not configure it with the default sizes, try to do it manually by adjusting thedimensions of the paper.
1helpful
Unexpected paper size in tray 2.the paper in tray 2 is legal size..8.5 x 13 custom size in philippines..
Papers come in different standards across the world. This size is neither US nor metric. You will need to set the printer for custom-size paper and enter the dimensions.
2answers
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
4helpful
Printer says 41.3 unexpected size in tray 2. How do I fix this?
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Papper gets stuck while printing,shows on the scren paper size,41.3 unexpected paper size.
Make sure the paper stops in the paper tray are set to the correct paper size. If one of them is not in the correct location the printer thinks it is a different size of paper. Also make sure the selector on the tray is set to the correct size. If all these are good you should reset all the settings to default.
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
Hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
