My card work properly another camra,but not work in my camra nikon d40. please help me soon.
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
SOURCE: cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
SOURCE: Camera is saying "Memory card is locked. Slide lock to "write" position."
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
SOURCE: my d80 cameras memory card locked automatically when i insert in
it has a write proctect tab on the on the side of the card when its down the card will be locked ,slide it up to remove the lock.hope this helps pls do let me know
