The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
SOURCE: db60
If you have the beat generated, and merely want to save it, press Write Button once. Use the tempo up and down arrows to select the memory location and press the Write button again. it should store it.
If you are just looking for a different random shuffle, the metronome is hard coded and limited to what you can change on it.
If you did not get the owners manual, it is here:
http://media.rolandus.com/manuals/DB-60_OM.pdf
