I took the printer apart to clean the rollers and separator pad (per instructions of the User Guide) I removed the face plate in front of the machine. After putting it all back. Now, the feeder doesn't work. The other components (printing, scanning and faxing) still work fine. Can i find a replacement feeder part?
SOURCE: HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
SOURCE: Faxing documents
http://h10032.www1.hp.com/ctg/Manual/c00278645.pdf
click on that link for the manual for your officejet
SOURCE: HP LaserJet 1012 Printer prints ghost images
A new toner cartridge solved the problem entirely.
SOURCE: HP officejet 4355 all in one print fax scan copier to connect wit
Hi there, and welcome to FixYa,
You will find your driver at this site:
- choose your operating system, download and install,
plz let me know the result.
/Teis
SOURCE: My Hp Officejet 7210 will not scan,fax or feed
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from our computers.
It would either grab several pages at once, or not grab paper at all. The feeder was trying but had poor traction action. Not sure if that's the same situation for you, but this is what fixed ours:
I purchased part number C7309-60091 feed roller assembly, and part number C7309-60076 separation pad from Encompass Parts, and replaced them. The ADF works great now.
Our HP Officejet 7210 had only 3,000 pages printed on it, which didn't seem like enough to wear out the separation pad or feed roller in the ADF, especially since all those pages didn't go through the ADF, so I figure it's because of our very dry environment. Hope this helps you.
Okay, I bought the replacement part HP 5851-3580 ADF Roller Assy for $14.29, the ADF paper separator $4.89 and the HP Flag for $3.38 from www.sparepartswarehouse.com. There were instructions included in the box and I swapped out the parts on the printer. Now, everything works like NEW! Hooray!
