At 68 degrees on "heat" cold air blows out, when I set it up to 73 degrees it's VERY hot! The problem fluctuates, as one day I had to turn it to 86 to get warm air to blow out, a few hours later had to turned it back to 73 and it was warm again. I don't know if this is related or a whole different problem but the heat only comes out the main vents on the dash. If I put it on "floor" or "defrost", it still only comes out the main vents.
SOURCE: heat only blows out of dash vents, will not blow out of defroster
vvacum leak. in back of your temp control unit there is a series of vaum lines attached together they might even be in different colors these lines go to the vent and they open and close them when you slide the lever over this piece needs to be replaced
SOURCE: blowing cold air when heat is on
air blend door jammed, or you have lost vacumn to the diaphram that opens and closed that door.
SOURCE: 2001 pt cruiser no heat
did you check the fluid level by removing the rad. cap? Radiator should be full to top. If Chryslers are low on coolant, the heater will not blow warm air.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
