1. Make sure
you use a moisturizer before you start shaving
2. Pull the
skin tight to create tension.
3. Shave in
the direction that the hair grows
4. If you have a beach or pool day out, make sure you shave the night before to avoid rashes and irritation from shaving.
When you shave with an electric shaver you want the opposite of what you want when shaving with a blade. You may want to prepare with a shaving lotion which is usually alcohol-based, to dry up the moisture on your skin and make the whiskers stand up straight.
Rashes can be caused by allergic reactions to the skin or the shaving products you are using. If you believe this to be the case, try unscented products or products designed specifically for sensitive skin.
To treat razor burns, look for a soothing after-shave balm.
Avoid alcohol-based aftershaves. You may also want to avoid shaving for a few
days in order to let the skin heal itself.
You should avoid using alcohol-based aftershave, as it will
dry out your skin. Instead, apply a toner with ingredients that will moisturize
and nourish your skin.
