The washer starts cycle and stops ( drain & spin cycle) & beeps and shows code F6.
Please help
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Kenmore elite washer stops mid cycle, beeps shows f 06 code. Clothes are very wet. tried spin drain cycle spins out more but still very wet. 1.replaced the control panel electrical board inside the washer-, 2.cleaned drain at lower front of washer, 3. checked drain hose in back of washer. What else could it be.
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
im having the same problem with my whirpool washing machine, it trys to spin then stops and shows the F06 code, does anybody know what it meens. cheeers steve
F2 code shows on display. Burners work fine, but oven does not work at all. I can clear the F2 display but it comes back on and keeps beeping. What is the meaning of this code and what part do I need to fix this problem?
