Seems the top of my artisan mixer is stuck and need to replace some parts.
I bought my mixer in the US and i'm living in Suriname, so there isn't any waranty.
Any ideas?
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
service repair manual
check it out
To remove the top look in the rear of the motor head and you will see a phillips head screw. Remove that screw and then the band will come loose and can be removed. Now you will see two more phillips head screws on each side under where the band had been. Remove them and the top of the motor will lift off.
good luck with it. please rate my answer.
