Belkin (F5D7000) 802.11g/b Wireless Adapter Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belkin Wireless G only connects at 11mpbs for an internal network
Running Windows Server 2003. I have 2 network cards. The main one is hard wired to my router. The other is a Belkin Wireless G PCI F5D7000. I want to set it up that all my computers connect to the Belkin to get internet connections for the laptops. I have it set to static, no default gateway. I created a SSID and am able to connect to it with the Belkin. It seems that the only way the SSID shows up is when it is set for an adhoc computer to computer setup. When the other computers connect to the Belkin they only connect at 11mpbs. The Belkin shows that it is connecting at that speed which is why the other computer connect only at 11mpbs. If I were to set it up to connect to my router and obtain IP and DNS automatically it connects at 54mpbs. Why does the Belkin only connect at 11mpbs internally? How can I get it to 54mpbs so that the other computers connection speed would be 54mpbs?
  • spartacu Feb 03, 2009
    How do you increase the frequency? Do you increase it in the router itself? It is set up for wireless b/g.
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Feb 03, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687531
Points
5322
U need to increase the frequency in wi fi router settings.
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
My Server can not conet to the network
Check your IP address and workgroup settings in the computer or try assign Static IP to the computer.
Belkin Wireless connection speed at 11mpbs. Why not 54mpbs?
this is from the d-link support page:
"Question :Why can't I get the advertised speed and performance when in Ad-Hoc mode?
Answer :
This FAQ applies to 802.11b, 802.11g, and Super G™products.
D-Link wireless products follow the IEEE 802.11 standards. The802.11b and 802.11g standards specify that Ad-Hoc mode only needsto support up to 11Mbps. For best results, use an access point orwireless router and set your adapters to Infrastructure (station)mode."
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Server cannot see wireless workgroup machines but shares Internet
Disable any firewalls on the machine like Windows firewall or any other firewall like Norton, McAfe, ZoneAlarm and something like that. Or if you have firewall policies or access rules, you must enable the sharing there.
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
