SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
SOURCE: I have a Samsung BD-C6900
I have sought to change mine to all regions, but have had no success, yet.
Here is a link with some info that might help.
http://forum.videohelp.com/threads/232568-DVD-Hacks-List-FAQ-%28region-free-macrovision-free-others%29
SOURCE: I want to make my
Hi
heres how its supposedly done.
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the firmware.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the eject button to open the tray. (The button is between
the "Power" and "TV Power" buttons at the top of the controller.)
5. Press the eject button to close the tray.
6. Wait while the player searches for a disk.
7. As soon as the "No Disk" message appears at the top left corner do the following.
8. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller.
9. Enter 5 7 5 3 8
on the number pad.
10. The region code "2" should appear at the top left corner of the screen.
11. Enter a "9" to make the player region free. (Enter a region code
if you want to lock the player to another region for some obscure or
perverse reason.)
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Now the tricky bits. This process is timing dependent.
Firstly, you must start entering the code just after the "No Disk"
message is shown and before the message disappears. If you jump the gun
or miss the boat it won't work.
Secondly, the REPEAT key is part of the code. All six keys must be
entered smoothly as "REPEAT 5 7 5 3 8
". The entry gets timed out so you
can't stop in the middle and restart. Don't bash away like crazy, just
do it smoothly and briskly.
If you don't see the "2" the first time, don't worry. Just repeat
the process. It took me about a dozen tries before I got it to work.
region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
--- since your player is locked to 2 you use this code.
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
SOURCE: my samsung bd-c7500 dont play
hi, As I live in Kazakhstan my BD-C7500 is locked to DVD region 5. Just use the codes at the end of this tutorial for your own DVD region. 5. The region code "3" should appear at the top left corner of the screen.
try the following
2. Switch the player on.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller - and enter 5 6 7 3 2 on the number pad.
6. Quickly enter a "9" to make the player region free. (Just try pressing 9 on the remote controller until you see 9 appear in the upper left corner of your TV screen.)
7. Open and close the disc tray. Power down and power up again.
For people from other parts of the world, all region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
ok
SOURCE: Region Free Procedure for Samsung
In this unit the only thing that can be modified is the region for the dvd, not the one for the BR. Follow this
1. Press RETURN (bottom left)
2. Press the access code corresponding to your dvd zone
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
3. Your current region code will appear top right of screen, Press 9 to
change to region 9 (no region).
