Casio FX-300MS Calculator Logo
A
Anonymous Posted on Feb 05, 2013
How to solve bisection method using 991 ms - Casio FX-300MS Calculator
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Apr 14, 2011
SOURCE: need help with fx -
I am not quite sure what you mean by ``solve f(x)=100x-64*x^2+48*x^3 for different value of x``. Do you want to find the roots of the cubic equation 0=100x-64*x^2+48*x^3 , or do you want to generate values of f(x) for different values of the variable x.
For the first case, use the SOLVE program,
for the second, use the TABLE computational mode: Press MODE and select TABLE, then enter the expression to the right of the equal sign. In TABLE, X is the default variable.
How to add biss to dansat 991
I'm sorry, but I cannot provide you with a BISS key or any other unauthorized method to access scrambled channels. Using unauthorized methods to view scrambled channels is ******* and can result in legal consequences. It is important to use legitimate methods to access channels and support the broadcast industry.
tip
4 Methods to Change MS SQL Server Password
Have you ever forgot or lost your MS SQL Server password? Did you reinstall MS SQL Server or change SQL Server Password by some ways at that time? I once forgot my MS SQL Server password and I reinstalled My MS SQL at last as I failed to find some good methods to solve the problem. What annoying and terrible experience it is! In order to avoid reinstalling SQL Server for a second time due to the same reason, so I collect some methods to change SQL Server password for sa account.
Method 1: Use Command Prompt to Change SQL Server Password
Step 1. Open a command prompt (Start -> Run -> cmd)
Step 2. Type the follow commands, and press Enter after each line:
Osql –S yourservername –E
1> EXEC sp_password NULL, ’yourpassword’, ’sa’
2> GO
The yourservername is the name of your server, yourpassword is the new sql sa password.
The command line 1> also can be changed to other command, the model is EXEC sp_password ‘oldpassword’, ‘newpassword’, ‘sqlaccount’.
Method 2: Use the Query Windows in Management Studio to Change MS SQL Server Password
Step 1. Open SQL Server Management Studio
Step 2. Open a new query
Step 3. Type the follow commands and excute:
GO
ALTER LOGIN [sa] WITH DEFAULT_DATABASE=[master]
GO
USE [master]
GO
ALTER LOGIN [sa] WITH PASSWORD=N'NewPassword' MUST_CHANGE
GO
The NewPassword is set for your SQL Server sa account.
Method 3: Change SQLServer Password by Windows Authentication
If Builtin/Administrator is present in SQL Server, you can login with an ID which is member of Administrators group and change sa password in SQL Server. Just do as follows:
1. Login into SQL server using Windows Authentication.
2. In Object Explorer, open Security folder, open Logins folder. Right Click on sa account and go to Properties.
3. Type a new SQL sa password, and confirm it. Click OK to finish.
After restarting SQL Server and all its servers, you can log into SQL Server by sa login with new SQL sa password.
Method 4: Change MS SQL Server Password with Third Party Software
In addition to the methods above, you can aslo choose some SQL Server password recovery tool to change SQL Server password. MS SQL Server Password Unlocker is one of the good MS SQL passwrod reset tools which can help you change SQL Server password in a few seconds. It allows you to chage MS SQL password on SQL Server and Express 2000/2005/2008.
Following is a guide for you to change MS SQL password with MS SQL Server Password Unlocker.
Step 1.Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with it.
Well, the four solutions are the easy-to-use MS SQL Server Password Reset ways.
on Aug 10, 2010 • Computers & Internet
1helpful
5answers
How do I recover a corrupt PowerPoint file?
If there was such problem, the simplest decision is described here:
Method 1:
Move the PowerPoint to different location : this is first and very useful troubleshooting method to repair PPT problems . Copy presentation and paste it on other computer hard.
Method 2: Open presentation in MS word document:
If you have tried above method, but still facing same problem then try to open corrupt PowerPoint in MS Word. Follow this below steps:
•Open MS Word.
•Click on Open button of File menu.
•Select Files of type box and navigate to your corrupt file, Open it.
Method 3: Use Safe Mode
To see your presentation in safe mode, first of all you will have to run PowerPoint in safe mode. Follow these steps to do it...
•Click on Start button.
•Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
•Now press OK button.
•Restart your system, during restart press & hold F8 button to start window in safe mode.
•Open & see your presentation.
If at you it didn't turn out to solve a problem, it is possible to try to solve it otherwise, for example as it is described here:
https://social.technet.microsoft.com/Forums/en-US/50c99db5-9167-44fe-b625-e2682fa682ca/corrupt-powerpoint-file?forum=officeitprolegacy
And also there is a universal decision and "an edition choice" it watch it here:
Online PPT repair tool
2helpful
2answers
How to restore all powerpoint 2010 files?
Hii..
There are different methods available to recover corrupted PPT.
Method 1:
• Open MS Word.
• Click on Open button of File menu.
• Select Files of type box and navigate to your corrupt file, Open it.
• Click on Start button.
• Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
• Now press OK button.
• Restart your system, during restart press & hold F8 button to start window in safe mode.
• Open & see your presentation.
Method 4: Try Third part repair Tool: If all above method fail to fix corrupted presentation then you can try third party PowerPoint Restore Toolbox
http://www.powerpoint.restoretools.com/
2answers
Runge kutta method on casio fx 991 ms
It can calculate numerical values of derivatives of functions and definite integrals but it does not solve differential equations.
Need help with fx - 991 ms to solve f(x)=100x-64*x^2+48*x^3 for different value of x
1helpful
2answers
Steps to draw graphs using Fx 991 ES Plus calculator.
There are many different functions...
You can download the entire manual after answering a few questions at www.safemanuals.com
after using the dropdown menu for this make and model.
Good Luck!
Each diagonal of a square measures 1 inch. if the diagonals bisect each other and segments formed measure x/3 and 1 - x/6. what are the exact measures of the segments Enter Problem: Help Math...
If the diangonal of a square is 1, either side opposite the diagonal is equal to the sin of 45 degrees. sin 45=.70710678. The segments formed by the bisection of the diagonals would be one half the length of the diagonal which would be .5 x 1 = .5. Or you could take the sin of .70710678x.70710678=.5 for the bisectors.
(if I understand what you are asking.)
2helpful
Instruction manual for Casio fx -991 Scientific calculator
There are plenty of casio 991 manuals here. Take your pick!
http://safemanuals.com/zearch_160.php
Dom't forget to leave feedback if it solves your problem. 'fixya'!
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
