Audiovox Rampage 1200 Watt Amplifier Car Audio Amplifier Logo
Anonymous Posted on Feb 03, 2009
6 disc rampage audiovox modulator
I have an 6 disc rampage audiovox modulator that has 3 wires one black,green,orange i just trying to know what wires go to the power,ground,remote
Anonymous
Level 2:
Scholar:
  • Expert 125 Answers
  • Posted on Feb 04, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
125
Questions
0
Helped
54854
Points
253
You can go to this address and obtain wiring and product info:
http://audio.manualsonline.com/manuals/mfg/audiovox/audiovox_stereo_amplifier_product_list.html
enter in product info model number etc.
5helpful
What is the wiring color code for a sony cdx-sw200
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope that is what you were asking for.
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
4helpful
2answers
Need the output wiring diagram for a AUDIOVOX 93-im-ETX radio
Wiring diagram for Audiovox 93-IM-ETX
Figured it out by taking radio lid off and following the leads:
Black/white--ground (-)
Green/white--battery (+, that is, always on)
Orange/white--ignition/ACC switched power
White--left front +
Red--Left rear +
Blue--right front +
Yellow--right rear +
Light Green--negative for front speakers
Purple-negative for rear speakers
3helpful
Wireing diagram/coloring?
Yellow: Constant Power (+)
Red: Switched Ignition Power (+)
Black: Ground (-)
White: Front Left Positive (+)
White/Black: Front Left Ground (-)
Grey: Front Right Positive (+)
Grey/Black: Front Right Ground (-)
Green: Rear Left Positive (+)
Green/Black: Rear Left Ground (-)
Purple: Rear Right Positive (+)
Purple/Black: Rear Right Ground (-)
Blue: Remote wire
Blue/White: Antenna wire
Orange: Running Lights
Orange/White: Dimmer Lights
2helpful
2answers
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Audiovox modulator
enter in product model number and info
Hi i have an rampage audiovox acc-40 and on the modulator it has 3 wires one green, black and orange i wanted to know what one is the power, ground, remote
just enter in product number and info
1helpful
I need a wiring legend for the Rampage BA200 sub woofer
Red - power
Black - ground
Blue - turn-on (switched 12 volt)
Green and Gray -- Hook to factory/aftermarket stereo for the signal.
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
2helpful
4answers
Motorola spectra
Those should be for the speaker.
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
