Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
hello
