Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Posted on Feb 05, 2013
Cold water fills very slowly
Hot water fills normally, but cold just trickles in. Removed hoses, and they are not plugged
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Feb 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
22906
Points
79
It's possible that sediment or a mineral buildup is in the water solenoid valve itself where you connect the hose. Try cleaning its screen, if this doesn't work, replace the part.
3 Related Answers
A
Anonymous
  • Posted on Sep 28, 2008
SOURCE: Frigidaire Full Size Laundry Center Model LCE-732L
Cleaned the lint screen and still have the same problem.
Carmen Mikulic
  • 415 Answers
  • Posted on Nov 05, 2008
SOURCE: frigidaire lws3312d washer not filling up
check the water faucets on the wall and make sure that both hot and cold are completely open.
check the water inlet hoses for any kinks or leaks.
Sal De
  • 2699 Answers
  • Posted on Nov 19, 2010
SOURCE: Frigidaire FTF2140FS front load washer.
shut off the water valve,disconnect the hot water hose from the back of the washer,then turn on the water valve to make sure it's not the house water valve first before you start messing with the washer,if the hot water is working correctly then you could have a bad water valve on the washer.let me know what you find
3answers
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
Won't fill with hot or warm water . hot and warm only come out in a trickle. cold water is the water that works normally
Turn off water supply valve behind washer and remove the supply hose from both ends. Look for a screened washer in the hose, which can be removed, cleaned, and re-inserted. Also, look for a screen to do the same with inside where the hose screws onto the machine. Re-attact hoses and turn water valves back on. Make sure hoses are not kinked behind machine.
2helpful
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
1helpful
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Kenmore 80 series model #110.26882503 fills slowly
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
