Question about Acer Aspire 1690 Notebook
No sound on my acer aspire 1690
I was prompted to download windows service pack 1, the download failed and since then i have had no sound
  • Acer Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Posted on Feb 05, 2013
6ya staff
SOURCE:
Anonymous
  • 202 Answers
SOURCE: no sound
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Posted on Aug 19, 2008
Anonymous
  • 128 Answers
SOURCE: my acer aspire 5520 laptop wont work after installing windows vista service pack 1
try this >> when you turn on your pc press f8 then choose "last known good configuration"
Posted on Oct 23, 2008
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: acer aspire 3680 lan driver from where i downloading for free
Hi , I am Milind . Copy the link and past to your Internet explorer. Download the driver.
http://drivers.softpedia.com/progDownload/Acer-Aspire-3680-LAN-Driver-855-Download-36382.html
Posted on Jan 11, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Aspire 1690 - Backlight on screen is failing Rose
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 08, 2009
john
  • 13 Answers
SOURCE: i wants sound drivers for acer aspire 1690
All acer 1690 drivers
http://www.driverstock.com/Acer-Aspire-1690-driver-download/4-21-12844/index.html
Posted on May 18, 2012
Cant load even service pack 1
Go to windows update, " type " windows agent and click search, it will be slow to respond, when page changes scroll down and click on windows agent, wait till it loads page then scroll down until you see the download, top is for 32 bit, second one for a 64 bit computer and click, follow the prompt, this will update your registry, it may take several minutes for the window update symbol to appear, put your windows XP in the DVD driver, when windows opens close it. the disc will start when update begin, leave disc in until all updates are complete, check windows update to make you have all updates.
Mar 09, 2012 | Computers & Internet
Microsoft updates do not install
You have not said which OS you are using so; from http://support.microsoft.com/kb/943144
When you try to install Windows updates from the Windows Update Web site, the Microsoft Update Web site, or by using Automatic Update, you receive a message that the update is not installed successfully. Additionally, the update is not displayed in the update history.
You may experience this issue in the following scenarios:
Scenario 1 You try to install updates after repair a Windows XP installation by using the Windows XP CD.
Scenario 2 You perform the following operations before you try to install Windows updates:
You perform a new installation of Windows XP Service Pack 2 (SP2).
You visit the Windows Update Web site, or the Microsoft Update Web site.
Note When you visit the update Web site, the latest version of Windows Update software will be installed in your computer.
You install Windows XP Service Pack (SP3) without a restart.
You try to install Windows updates after the install of Windows XP SP3.
Then cause ;
This issue occurs because the Wups2.dll file that is included in the latest version of Windows Update is not installed correctly.
For scenario 1, the registry entries that correspond to the Wups2.dll file are missing after the repair install of Windows XP. The release version of Windows XP does not contain the Windows Update software.
For scenario 2, the registry entries that correspond to Windows Update are changed back to the Windows XP SP2 version if you did not restart the computer before you install Windows XP SP3. The registry entries for the Wups2.dll file are changed to pointing to the Wups.dll file that is included in the release version of Windows XP SP2.
To resolve this problem, use one of the following methods;
Method 1: Download and install the Windows Update Agent,
For an x86-based computer; http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x86.exe
For an x64-based computer http://download.windowsupdate.com/WindowsUpdate/redist/standalone/7.4.7600.226/WindowsUpdateAgent30-x64.exe
Method 2: Register the Wups2.dll file,
To have MS register the Wups2.dll file in Windows for you, go to http://support.microsoft.com/kb/943144#FixItForMeAlways.
If you prefer to fix this problem yourself,
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Open the Command Prompt window. To do this, click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition, type the following command, and then press ENTER:
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK if you receive a verification message.
3. Start the Automatic Updates service. To do this, type the following command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the Command Prompt window. To do this, type exit at the command prompt, and then press ENTER.
Jun 02, 2011 | Microsoft Computers & Internet
How to installation windows xp in hindi lenguage with picture
  1. Step 1 Open Windows Update (located in the Windows XP Control Panel), and see if SP2 is on the list of available updates. If you don't have Windows Update installed or turned on, visit the Windows Update website in order to get the latest Windows Update software.
  2. Step 2 Select the Windows XP SP2 item from the list of available updates, and click the "Install" button. Windows Update will begin downloading Service Pack 2 (a process that may take up to 20 minutes or longer, depending on how fast your Internet connectionmag-glass_10x10.gif is), and will then launch the installation program once downloading is complete.
  3. Step 3 Follow the on-screen prompts to complete the Windows XP Service Pack 2 installation. You will be asked to accept the terms of the licensing agreement before the actual installation takes place. Installation may take up to 20 or 30 minutes, after which you will be required to reboot your computer in order for the changes to the operating system to take effect.
  4. Step 4 Should you have problems installing XP Service Pack 2 through Windows Update, download the stand-alone executable from Microsoft in order to install the software update manually. The Service Pack executable is designed to make it easier for IT professionals to update multiple computers without having to download the Service Pack onto each one. Run the installer program once you've finished downloading it, and follow the on-screen instructions as mentioned above.
May 30, 2010 | Microsoft Windows XP Professional SP2
Try to download Windows Vista Service Pack 2 KB9848465 and received this error code 800F0A0A. Thanks for any help...
Workaround
To work around this issue, uninstall the August 2009 Windows Vista and Windows Server 2008 Application Compatibility Update, and then install Service Pack 2 for Windows Server 2008 and Windows Vista. To uninstall the August 2009 Windows Vista and Windows Server 2008 Application Compatibility Update, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Click Uninstall a program under the Programs section.
  3. In the Tasks list in the left navigation area, click View installed updates.
  4. Click Update for Microsoft Windows (KB972036), and then click Uninstall.
  5. Click Yes when you are prompted to confirm the uninstallation.
    Note If you are prompted for confirmation or for the administrator password, click Yes to confirm, or type the administrator password.
  6. Restart the system when you are prompted.
If this helped you then please help me and vote kindly, thank you.
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
Laptop wont work after installing vista service pack 1
Please try booting from OS CD then go to command prompt (fix windows from console).
Then chose the right os (in case you have more than one)
then type in your admin password (in case you have one)
then type fixboot at the command prompt.
Hopefully it'll help... if not please drop a line I'll take it to the next phase.
Thank you for using agadycom.
Nov 21, 2008 | Microsoft Windows Vista Home Premium with...
Failure in installing realtek Hd Audio driver
remove the space and the link will work.
http://www.bram.us/2008/08/20/fix-to-the-hd-audio-bus-driver-failed-to-load -0xe0000227-realtek-high-definition-audio-driver-install-has-failed-errors/
Aug 09, 2008 | Microsoft Windows XP Professional With...
Service Pack 3 for Windows XP
Your problem is there's no such thing as Service pack 3.
Are you sure it's not service pack 2 you're trying?
Nov 07, 2007 | Microsoft Windows XP Professional for PC
Acer Aspire 1690 Notebook Logo
63 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
