Recently replaced the thermal limiter in Frigidaire Affinity AEQ6700FSO electric dryer, once we turned on the dryer to run a cycle, it didn't heat at all. The dryer ran for about 10 minutes then stopped running, but the display was still on.
SOURCE: (2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
SOURCE: Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
SOURCE: I have a frigidaire affinity dryer that won't heat
CHECK THE THERMAL FUSE, OR THE COILS LOCATED OT TOP OF THE GAS VALVE CHANGE IT
SOURCE: Frigidaire affinity E 61
CHECK IF FAN IS SPINNING AND IF EXHAUST IS CLEAR MAY BE GOING ON OVER TEMP
