Pentax Optio A10 Digital Camera Logo
Brian Anderson Posted on Feb 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card error - Pentax Optio A10 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Pentax Master 102,366 Answers
  • Posted on Feb 05, 2013
Pentax Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10437964
Points
622693
What type and size memory card? The A10 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 • Cameras
Memory harddrive corrupt in satio TM
well, bro! I think your phone memory card is error or damged, because of the frequent data transport, and the reasons for error memory card are various, for example unpluging memory card without shutting down mobile phone, formatting the card in wrong way, and virus attack, etc.
and after error, the data in the memory card may damages and you have to formate the memory card for reusing. And how to recover data from error memory card, you can know more from here: http://goo.gl/CMfQI
2helpful
2answers
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
25helpful
5answers
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
1helpful
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 • Optics
26helpful
5answers
Memory Card Error after Formating memory card
instead of quick format, use the full format.  Then put back in your camera and format again with the camera.
16helpful
2answers
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Aug 04, 2008 • Cameras
2helpful
3answers
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
