I have a Maytag HAV2357AWW when my clothes went into spin cycle it begin smoke and there was a burning smell. I notice this after trying to fix the off balance problem I was having with the load.
our machine does"nt rinse or spin we have changed the belt and no cold water comes either please let me know what I can do thank you
AnonymousApr 21, 2009
The washing machine just stopped and I went in to check on it and smoke came out of the tub - could it the the motor and how expensive is the motor?The washing machine just stopped and I went in to check on it and smoke came out of the tub - could it the the motor and how expensive is the motor?
You can't post conmments that contain an email address.
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
