KitchenAid Microwave Convection Oven Logo
A
Anonymous Posted on Feb 04, 2013
KitchenAid #KEMS308SSS00 set time & push start, light inside comes on momentarily & display reads "start?" It acts like it wants to start when you push start button,but nothing. No the lock is not on
2 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 23, 2008
SOURCE: buttons on microwave do not work at all
Yes. The time base is important.
You could unplug it and try it again, but it may not work.
Another model's manual says, "a 120 Volt, 60 Hz,
AC only, 15- or 20-amp fused electrical supply (or circuit breaker)
is required."
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 08, 2008
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Kitchenaid KEMS308SSS00: when I open the microwave door now, instead of light coming on, the turn table turns!
It's a guess, but something mis-connected on that new board. They usually have a number of edge connectors and you have two on the wrong pins. A guess never the less.
Kitchenaid KBMS1454BSS Starts and stops, then restarts and stops, etc, at different intervals.
PDF]BUILT-IN MICROWAVE OVEN Use & Care Guide - KitchenAid
www.kitchenaid.com/.../KBMS1454BBL/Use%20and%20Car...
KitchenAidWe have provided many important safety messages in this manual and on your appliance. Always read .... Touch CANCEL/OFF and reset the clock if needed.Missing: kbms
KitchenAid kbms 1 Kitchen Ranges Questions & Answers ...
www.fixya.com > Forum > Tags > kbms 1 > Kitchen Ranges
KitchenAid kitchen ranges kbms 1 related questions and answers. ... Control panelreset answer Steve, Thanks for providing your answer to my question about ...
How to reset clock the clock on my KitchenAid Microwave Convection Oven
Usually push click button than set time and push click button again (some will have you push the "start" button)
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
My microwave displays time etc, but does not turn on
That model number from the tag on your oven should be KCMS1555SS0, KCMS1555SS1, or KCMS1555SS2.
We would need more detailed information about what it's doing or not doing.
Does it respond to key presses?
Does the inside light come on when you open the door?
Can you enter the cooking time?
What happens when you press "Start"?
Does it run but not heat?
Does it count down but the inside light and fan do not come on?
Please post a new help request with the model number and detailed sympotms.
When you push cook time and a time, or just hit the auto 1,2,3,or 4 minutes, it lights up on the display like it is cooking, with the timer till finished going and everything, but it does not actually...
Highly likely your microwave has "failed".
Down inside the microwave is a part called the Magnetron. This is the part, (about the size of your fist), that makes the sound waves to cook the food.
On some models, it can fail, whilst all the other stuff works.
3 possibilities:
1) You need a fuse replaced.
2) You need a capacitor replaced (That part "starts" the magnetron) or
3) you need a new magentron.
In any regard, very often people will not opt to have it repaired, because the labor & parts can cost more than a new Microwave.
God bless your efforts.
My Kitchenaid KHMS 155LSS-4 makes a clicking noise upon starting for about three seconds, then will act like its heating but will not heat. The noise repeats itself every 20 seconds. It did this when I...
Is there any fault code displayed on the display, such as F6?
I would first suggest checking the door switches and mounts.
If they are good, I would suspect the control board. We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
[email protected]
3helpful
Kitchenaid double convection microwave / oven combo model #kems308sss00. Error code: f6 eo, lost communication. What do I do?
[email protected]
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
