Lenovo series is G580,when i pressed shutdown button on start it is not shutting down.please give me reason and how to solve this problem?
SOURCE: windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
SOURCE: automatic shutdown problem with my DELL laptop
Sounds like you need more ram,,or your processor is too slow.
SOURCE: Lenovo Laptop Stuck up while shut down
let it set if u turn it off by the buttons while its shutting down u'll have to format hard drive and reinstall you system
SOURCE: lenovo Y510 stuck on logo screen at startup
Your hard drive maybe failing. I would make a back up as soon as possible . Then I would do a dskchk, Here's how:
Double-click My Computer, and then right-click the hard disk that you want to check.
Note If one or more of the files on the hard disk are open, you will receive the following message:
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Please don't forget to rate this solution.
SOURCE: Dell Latitude d600 series.The shut down after start-up
when your computer is freezes up then you download registry mechani it can improve your performance
