Uniden BC898T Base Scanner Logo
Posted on Feb 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New to scanners - BC898T - how to search
Just bought a BC898T. I'm not sure if it's me (and it could be) or if the scanner is defective. I've been trying to get the scanner to search in order to find active frequencies. I guess I need step by step instructions. The owners manual/users guide is not much help
Thanks.
  • Anonymous Apr 05, 2009
    how to search for chanels
  • neilb1 Apr 21, 2009
    I try to program ONE CHANNEL and get an ERROR message.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
729
Points
I cant get the scanner to search all frequencies
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Dec 12, 2009
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934148
Points
7369
To set up a search on the BC898T:
- Turn the scanner ON.
- Press MANUAL to stop scanning.
- Press SRC.
- Press HOLD.
- Select a memory bank by pushing one of the bank buttons (A through J). You can set up a search range in each memory bank.
- Enter the lower frequency (where the search will start), including the decimal point.
- Press E.
- Enter the upper frequency (where the search will stop).
- Press E.
Your search parameters are programmed. To search, push MANUAL to stop scanning, SRC to enter search mode, and the letter(s) for the memory bank(s) that you want to search.
I hope this helps.
Anonymous
Level 1:
  • Posted on Jul 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
729
Points
How do i reset my scanner so all the channels will show 000.000
I need a manual for a scanner made by uniden model # bc898t
amazon or ebay they are the fastest and cheapest for most manuals
My squelch button stopped working on the BC898T Base Scanner
Trunking is designed this way. You wouldn't want to listen to the control channel data, or you would never hear any of the actual radio calls. It sounds like it is working as it should.
I have a bc98t, and the manual direction to program a ctcss/dcs tone will not lock. Is there any more information that can help
If the tone will not lock in the search mode then that means that the user is not using tone or that the user may be using a non standard tone.
1helpful
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
How do I program conventional frequencies into my Uniden BC898T? I have Motorola TypeII Digital Tunking frequencies programed into Bank A and EDAC Digital Trunking frequencies programed into Bank B
Just go to Bank C or anything after that and start entering -- one channel, one frequency. It's kind of cumbersome to do by pushing the keys, but it works. An alternative is to use the BuTel software. It will simplify programming and give you Virtual Control of the scanner through your computer.
If this helps, please give us a rating. A "very helpful" would be greatly appreciated.
1helpful
Program a uniden bc-898y
I can't find any record of a BC898Y -- do you mean BC898T? Programming is much too involved for a detailed discussion here, and you didn't mention any specific problem. Here's a link to the owners manual. It will walk you through the entire process, and I hope it helps..
2answers
Trunking
Here's a link to Radio Reference. You can search their database for active systems in your area.
http://www.radioreference.com/apps/db/
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
