Although in theory, a manual toothbrush can clean the teeth effectively, most people do not spend the time needed to brush the teeth properly when they use a manual brush. For those people who do not make the effort required to use a manual toothbrush correctly, an electric toothbrush will be far more effective at keeping the teeth clean.
Here are some of the reasons why dentists recommend using an electric toothbrush instead of a manual toothbrush:
1. The mechanical action of an electric toothbrush will dislodge food particles better.
2. an electric toothbrush can clean more thoroughly between the teeth.
3. a sonic toothbrush can help prevent plaque build up below the gum line.
4. electric toothbrushes work more effectively for those who have arthritis.
For more details check out: Best Electric Toothbrushes of 2017 Guide and Reviews Guidezilla
The electric toothbrushes are great way to keep your teeth clean and away from gum problems. It offer great features to maintain your oral health, provide different cleaning modes.
The basic goal of electric toothbrush is to remove any attached dental plaque and deep cleaning.
You will also get touch control, pressure sensors, LCD display, different modes for easy brushing.
Top 5 Best Electric ToothBrush Reviews
Electric toothbrushes are an excellent tool to keep your teeth clean and
healthy. They offer many advantages: •
They allow you to remove plaque more efficiently and
quicker than manual toothbrushes. •
You don't need to brush hard in order to get good
results. This means that you are much less likely to injure your gums. •
People who suffer from physical conditions like
arthritis find electric toothbrushes as a great replacement to manual
toothbrushes because they are easier to grip and you don't need to use as much
physical power to get your teeth cleaned (the powered brushes do the cleaning). •
It is more fun to brush with electric toothbrushes
compared to manual toothbrushes, especially for children.
No, you should put the same amount of toothpaste on all types of
toothbrushes. You should put enough so you can clean your teeth well.
The main advantage of manual toothbrushes is the cost. They are much
cheaper than electric toothbrushes. Whereas an electric toothbrush can cost you
$50-$100, manual toothbrushes can be bought for just a few bucks. Another
advantage is that manual toothbrushes come in different sizes and colors, so
there's a larger variety to choose from.
The best electric toothbrushes are the Oral-b Professional Care and the
Phillip Sonicare Diamond Clean. You can find more information on these electric
toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
The main downside of electric toothbrushes has to be their cost! They are much more expensive than the manual toothbrushes and typically cost between $50 and $70. In addition, the heads of the electric toothbrushes must be replaced every three months, adding to the cost.
