When i turn on the laptop all i have is a blank screen I have been able to switch it on once and now i cant get it to turn on now please can somone help
Hello there
Description.
When pressing the notebook power button nothing is displayed on the
screen or display. The cause of this problem may be a failed AC
adapter, the memory modules (RAM) need to be reseated or a failed
notebook system board component which will require an HP certified
repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution.
Test the AC adapter
Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED.
Check the power indicator light or power socket LED
On
newer models of notebook PCs, there is an LED or indicator light around
the power socket on the notebook. Check to see if this light is on or
off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
The light does not turn on when the AC adapter is connected
If
the power indicator LED is off, the AC power adapter may need to be
replaced. To determine if the AC power adapter needs to be replaced
follow the steps below:
If
the power indicator light still does not turn on, then the AC Adapter
needs to be replaced. Contact HP Service and Support for further
assistance.
Power socket LED or power indicator light is on but the notebook does not start
If
notebook power indicator light (LED) is on, the AC adapter is working
correctly. The problem is a result of a hardware failure in the
notebook itself. In some cases, reseating the memory module (RAM) may
solve the problem.
NOTE:
To check the wall outlet, plug in a different known working device like a light, radio etc.
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Hp pavillion dv2036ea wont start up ac adapter works got light around socket and led charge indicator works, please help!
Please check previous posts about this, and read the following link about HP's enhanced warranty for this problem. If you think this is the same issue, then call the special HP number in the article. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
All the light come on and the screen stays blank
ih va tryed alll this and still go the same problem?
blank screen like laptop is in sleep mode. What a load of rubbish 2 years old with university work installed.
do the system lights come on?
