Computers & Internet Logo
Posted on Feb 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my wd media player reconize my tashiba external drive
All the lights come on on my hard drive but my WD media player will not sync it shows a folder option but says folder is empty. i plugged 3 other drives to the WD media player and it syncs just fine i plug my hard drive to my computer and it is recognized no problem but why wont my WD media drive sync to the hard drive?
pankaj rautela
Level 3:
Genius:
  • Master 1,252 Answers
  • Posted on Feb 04, 2013
pankaj rautela
Master
Level 3:
Genius:
Answers
1252
Questions
0
Helped
333588
Points
3358
Check whether the folder of you wd hard drive are hidden
2 Related Answers
Xeogin
Sean McCall
  • 9 Answers
  • Posted on Jan 26, 2009
SOURCE: New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Anonymous
  • Posted on Jul 19, 2009
SOURCE: How do I completely remove the WD Sync software
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
WD starts up ok, but does not recognize the external hard drive.
Check the menu, I beleive you have to tell the unit to search for an external drive. You also may have to have the drive already plugged in and running for the WD unit to see it when it does it's imput scan. I hope this helps
tip
How to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player
WD TV Mini Media Player provides an easy and affordable way to play back your digital media on your wide screen TV.  It serves as a conduit between your TV set and USB drive storage, no matter it is a camcorder, a humble flash drive, or an external HDD. Simply connect WD TV Mini to your TV, plug a USB-connected storage into the player and you are ready to enjoy all your digital media in DVD quality playback.
WD TV Mini Media Player supported media formats:
Videos:
AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10
Audios:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE
From the above list we can see that VOB is a playable format for WD TV Mini Media Player, does it mean that WD TV Mini can play all kinds of DVDs – whether home made DVDs or commercial DVDs? The answer is WD TV can not decrypt copy protected commercial DVDs, so you have to rip them. This tutorial aims to show you how to make it possible for you to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player. What you will need is Pavtube DVD Ripper, it not only rips, but it encodes too. Following is the detailed operating steps:
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load DVD files into this program.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle" and "Audio" respectively to select your needed subtitle and audio language.
Step 3: Select output format for WD TV Mini Media Player
Click on the drop-down list at the end of "Format" to choose an output format for WD TV Mini Media Player. Your selection should be in the range of AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10. Here I select "Xvid AVI" as an example:
Step 4: Click "Settings" button to adjust video and audio parameters
The user manual tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 5: Click "Convert" button to start DVD ripping
Once finished, you can get the generated files for WD TV Mini via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV Mini to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your commercial DVDs.
For more: http://www.pavtube.com/dvd_ripper
2helpful
I have a Buffalo Drivestation External USB 2.0 hard drive, when i try to watch a movie through a WD hd media player, after about 2-3 min the media player says that the HD has been unpluged and i need to...
that drive station sint truely supported by wd hd media player make sure you have our pwoer conncted to your external usb connection. let mek now if this helps
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
How to recover WD passport250 Data
hi...if you want to see again the files on the external hard drive i suggest you make to re-install the windows or repairs the windows you`re using or try to update the mother board drivers..thank you...^_^
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Grand Canyon Tech
Grand Canyon Tech
