Both are not very old, about 4 years I think. Also had a little water coming straight down out of the intake grill. Covered two little holes on each side of unit, no more water. The holes were always there, part of the design, don't know purpose. The thermostat can show 65 or lower real temp. and 67 desired temp. But it doesn't come on.
SOURCE: No heat, just cold air blowing
the problem you are having is usualy related to. #1 a high limit condition.(check the filter,then cycle the power off then on). Does the furnace have a diagnostic indicator?
SOURCE: My upstairs heating is blowing
Question: Is your heat produced by a furnace? (If so-- what kind of fuel?)
Or is heat produced by Air Conditioning nits working in reverse-- called Heat Pumps?
If Heat Pumps, You realize that when it gets very cold outside, there is not much 'heat' out ther, to get the heat from outside temperature, right?
Sometimes the out-door coils will freeze up, and you get even less heat then--
Please tell us more-- so we can take the clues you give us, and we'll trouble shoot the problems as best we can remotely, like this-
Mack B
Hello, the low voltage fuse will blow if the thermostat wires are shorting togethur or ground, or if the contactor coil on the outside unit is shorting to ground.
