Computers & Internet Logo
Posted on Feb 02, 2009
Memory Access Violation
I have a problem with accessing to my company data in tally.. when i select the company and it begins to load, it gives me an error message :
Exiting Tally
Internal error . contact tally solutions
Software Exception c0000005
(Memory access violation)
and i have no other options but hitting OK then it exits
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
889
Points
13
How slove memory access violation
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to [email protected] .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//www.tally9.info
http//www.tallyerp9.com
I found this howto here: https//answers.yahoo.com/question/index?qid=20100521043632AAsKkQs
44helpful
4answers
Quattro pro 9 is very slow in saving files over netwrok
Exiting Tally
4helpful
2answers
Sub : TALLY 7.2 error
exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
66helpful
5answers
Memory violation in tally 7.2 release 3.13
in some ledger we see the problem softare exception c0000005(memory access violation)
24helpful
5answers
Have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
1helpful
2answers
My tally 9 single user not opening my selected company
i have problem regarding tally9 internal error
software exception errorc0000005
[email protected]
Grand Canyon Tech
Grand Canyon Tech
